volume meshing using known boundaries
Hi,
I am trying to create a tetrahedral volume mesh between two components (red and green coloured geometries), I am aiming to have the hexahedral nodes as fixed for the new tetrahedral elements.
I was thinking to extract the inner surface of the red component and then have a closed volume to generate the mesh, my problem I even couldn't find a way how to extract this inner surface?
Could anyone help, please!
Many thanks,
Farah
use the command Tool >> faces and pick your hexa mesh component.
It will generate a shell mesh over the hexa faces. Then you can delete the unnecessary elements and keep only the internal faces, that will be used to compose a closed volume for your tet mesh.
