How to modify hyperview visualization
User: "RdelCuvillo"
Altair Community Member
Updated by RdelCuvillo
When I open HyperView and plot a contour, the legend is presented by default. It is possible to customize and save the legend. Afterwards, when you open a new file, you can load the previous TCL legend file.
Is it possible to modify the default parameters to always have the same format when you open a file? Specifically, can the TCL legend file be applied automatically without the need to manually load it each time?
1 - 4 of 41
    User: "Varun Venkateswaran"
    Altair Employee
    Updated by Varun Venkateswaran
    You could add a statement like this
    *DefaultPostContourLegendFile("<file_path>/custom_legend.tcl")
    in <install_directory>\hwdesktop\hw\prefinc\preferences_post.mvw
    User: "RdelCuvillo"
    OP
    Dear Varun,
    Thank you for the answer. However, I tried what you proposed addapting to my path and file name, but the default legend has not changed.
    Indeed, I found this row and changed the path and file name.     DefaultPostContourLegendFile("c:/tmp/clegend.tcl")
    Is there any other option? for example, running this command in the start-in directory. If I run it once it has oppened, it works fine.
    hwc result scalar legend import "<file_path>/custom_legend.tcl"
    Thank you in advance.
    Altair Employee
    The preference statement needs a * in front of it to become active, as shown in my example above.
    Could you please make sure you have added it?
    User: "RdelCuvillo"
    OP
    Dear Varun,
    You were right, and I was missing the *. This is because the original file does not have it.
    It works well. Thank you very much!
