Altair RISE
Nominate Yourself Now!
Hypermesh, Include Files and Export for LS-Dyna
User: "zoltaaaan"
Altair Community Member
Updated by zoltaaaan
Hey everyone,
I ran in some problems again and wanted to know, if there are easy fixes that prevent me from adding too many manual changes to my include keyfiles.
In Hypermesh, I set up a model for LS-Dyna with a tree structure of include files. Some include files are positioned with the Transformation Manager (*INCLUDE_TRANSFORM).
I have two issues at the moment:
1) Remove Transformation
I imported a model as an include and then added a transformation to it. The include type changed from 'Include' to 'Include_Transform', that worked fine. After some more changes, I wanted to change the type back to 'Include'. I deleted the transformation in Transformation Manager, but the type is still 'Include_Transform' now I have the issue that upon export, there is no '*INCLUDE' or '*INCLUDE_TRANSFORM' keyword written in the keyfile.
How can I change the include type back?
2) Prevent export
I have an include file, which is structured in another include file (e.g. in my master file it says '*INCLUDE file_a' and in file A it says '*INCLUDE file_b'.
Now I unchecked the export box in the model browser for file B, because I do not want it right now. File B is rightly not exported, but in file A it still says '*INCLUDE file_b', which gives me an error message, since file B does not exist.
How can I prevent this error from happening?
Edit: I found a solution. Simply check a box at 'Remove include file reference based on export status' which you can find under Export Browser > Solver Options.
Thank you in advance :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
