🎉Community Raffle - Win $25
Join and Win
Tensor Plot: Reduction of Arrows
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
i want to do a tensor plot of principal strains in HyperView using a .h3d file. The problem now is that the plot is rather difficult to read since i have small elements and therefore to many arrows on my screen. Is there a possibility to lower the number of arrows plotted?
I would really appreciate your help thanks.
best regards
Thomas
1 - 6 of 61
    Altair Employee
    OP
    Hello,
    normally every element get the tensor plot arrows. But you can select elements at the 'Selection:' panel, so only for the selected elements the tensor is plotted.
    In addition you can switch on/off the components (e.g. plot only P1 (Major).
    Best regards,
    Mario
    Altair Employee
    OP
    Thanks for the answer. This sounds like a good hint. Do you have a way/ a routine to select only every second element?
    Altair Employee
    OP
    Please refer to the image below:
    <?xml version="1.0" encoding="UTF-8"?>post-7616-0-43758200-1421139077_thumb.jp
    Altair Employee
    OP
    Hi,
    so for further clarification: i select only P1. I select all elements on my component. Since i have a fine mesh, arrows are not really visible on my part. See the image.
    So I am looking for an option to reduce the number of the arrows. Or to select only every second element... The aim is to get less arrows on the part to have better interpretation possibilities of the P1.
    <?xml version="1.0" encoding="UTF-8"?>post-36041-0-95452800-1421140036_thumb.j
    Altair Employee
    OP
    Hi,
    again me. Is there anyone who has a clue how to solve this. Or is there just no easy way doing this in HyperView?
    User: "Rahul_P1"
    Altair Employee
    Updated by Rahul_P1
    Tom,
    There are several options in the extended selection menu, you can use any one of those for your purpose,
    <?xml version="1.0" encoding="UTF-8"?>post-4438-0-51040400-1421401706_thumb.jp
    perhaps you can select a few elements and then use by adjacent or by attached etc
