frequently using material data
User: "mpvnaresh"
Altair Community Member
Updated by mpvnaresh
Hi
whwn i am doing a analysis for number of times(with different loads) I want to reuse the same material data ..Is there any way i can save the material out of HM file and recall it to the next modeling file.
1 - 6 of 61
    User: "tinh"
    Updated by tinh
    Yes, move it into an include, when exporting you will get 2 files link together, just change load in 1st file and keep constant data in the included file
    User: "mpvnaresh"
    OP
    many thanks for your quick  reply and very useful trick..
    I was not clearly explained my question.
    I want to re use the same material in all my analysis with different designs ...so i wantsave time in creating material all times and checking all values given are corect from the source .
    Simply to say ..in few other CAE softwares we can export material  to a .dat file and can be imported in to other files during PRE PROCESSING . do we have any option in HM..
    User: "tinh"
    Updated by tinh
    Yes, HM can.
    Pls use export tab (File>export) to export mats to a file, and import it to reuse
    User: "mpvnaresh"
    OP
    So in the export option all need to be deactivated , except a material .and imported ?
    User: "tinh"
    Updated by tinh
    You choose custom
    Or simply delete other entities than materials before exporting
    User: "mpvnaresh"
    OP
    Thanks ..
