🎉Community Raffle - Win $25
Join and Win
Hypermesh boundary layer mesh repair
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Please tell me, How can I repair the boundary layer mesh with the following quality criteria.
1.Aspect ratio <5
2.skew <60
3.tet collapse <1
1 - 8 of 81
    User: "QuyNguyenDai"
    Altair Community Member
    Updated by QuyNguyenDai
    Boundary layer mesh is often created from HEX/PENTA element.
    • This special type of elemenent used for CFD has very small thickness. So don't check 'aspect ratio' !
    • No TET elements, so no 'tet collapse' checking
    Altair Employee
    OP
    I have registered for the Altair optimization contest.In that, they gave guidelines on meshing.I attached the image of meshing guidelines please take a look.
    Hmm, do you prepare mesh for CFD?
    I do often CFD mesh with aspect ratio ~ 10-15 for boundary layers.
    Altair Employee
    OP
    I prepared the CFD mesh and checked the quality.When I checked the 3d mesh quality it shows the total boundary layer 3d elements as failed elements.Is it possible to do the mesh with the above-given procedure?
    Believe me, I make CFD mesh with boundary layer having aspect ratio ~10-15 and my CFD team got always good results :-)
    Attention: If you respect ratio < 5, your mesh maybe becomes too big to solve!
    So in numerical world, as in the real life, we have to found good compromise :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    Altair Employee
    OP
    Thank you so much for your reply.
    Altair Employee
    OP
    Could you please explain the procedure which was mentioned below.I don't know how can I create a volume mesh in Hypermesh for CFD.
    Have a look at CFD Meshing tutorials?
