🎉Community Raffle - Win $25
Join and Win
CFD-DEM coupled simulation for snow accumulation on a geometry
User: "Kiran Purushothama Keshavan"
Altair Community Member
Updated by Kiran Purushothama Keshavan
Hello all,
I was going through the article given below to simulate snow accumulation on a car geometry.
Link
The methodology is a complete DEM approach, what would you suggest for a coupled solution through a CFD - DEM approach to the same snow accumulation on this geometry. I'm particularly thinking of meshing and how I need to setup the simulation.
My aim is to couple Ansys Fluent with Altair EDEM,
Any insight would be greatly appreciated.
Regards,
Kiran
1 - 1 of 11
    User: "Stephen Cole"
    Altair Employee
    Updated by Stephen Cole
    Hi Kiran,
    From the DEM perspective the CFD solver is 'just' adding another force to the particles so a lot of the mesh considerations are independent of the EDEM solver.  You  could look at 1-way coupled solution if the flow field is not going to change over time in which case you can choose what mesh is best for the CFD or 2-way where you need to consider the mesh in a bit more detail.  If you use EDEM-Fluent you have to have the Fluent mesh larger than the particles or if you use EDEM-AcuSolve you can have smaller mesh cells on the CFD side.
    We have some EDEM-Fluent e-learning here https://learn.altair.com/enrol/index.php?id=171
    and EDEM-AcuSolve (shortly to be updated to show latest GUI) here - https://learn.altair.com/course/view.php?id=176
