I am using hypermesh (with Abaqus solver) I have inp files of a previous revision.
The details of geometry change, requires remesh entire part. Is there an efficient way to reconnect the contacts/ connections without redoing all of them?
I thought that perhaps I could remesh the part , and create the mesh inp file, and copy that into the previous inp and maintain the contacts/connections.
What is most efficient method in this situation ?
Thank you
