Automator Input Dynamic File Names
I need to import the latest version of a file located in a named path folder.
Can anyone point me to a guide for what Automator can work with?
The format for my file names is as follows.
XXXXXXXXX_YYYYMMDDHHMMSS_XXXXX
(where X could be any character but static for each report title, and the date/time is when the report was created)
Hi Craig,
Are you using Automator for this? If so, for the HHMMSS you can either do "?" for each character or * for a string of characters until the _XXXX begins. Found in the DataWatch help of Monarch, the ? in the top right. The note below says it doesn't work with numeric values but I have used it before like my examples.
So you would be looking at something like this:
XXXXXXXXX_&[YYYY]&[MM]&[DD]??????_XXXXX or
XXXXXXXXX_&[YYYY]&[MM]&[DD]*_XXXXX
Also if the date is for yesterday
XXXXXXXXX_&[YYYY.-d]&[MM.-d]&[DD.-d]*_XXXXX
I hope this helps.
Pat
Hi Craig,
I hope this helps.
Pat
Patrick,
If fields that look like dates or numbers have been "extracted" as character (or converted to character type or otherwise treated as character) I suspect the constraint you highlighted would not apply.
Grant
Hi Craig,
I hope this helps.
Pat
Thanks all- I've got a slightly different question on dynamic paths posted if you have thoughts. Thanks again.
Update- I've figured out the YYYY, MM, DD. (&[YYYY]&[MM]&[DD] etc.) I'd like to ignore the HHMMSS as they will be impossible to match, but continue with the second set of XXXXX.
