🎉Community Raffle - Win $25
Join and Win
Element Entity Set won't export
User: "William Kuo_21386"
Altair Community Member
Updated by William Kuo_21386
Hello!
I am an issue with exporting an entity set set. I set my solver export to display with abaqus explicit. The only components that are displayed are the solid tetras. I have multiple other entity sets. Three element entity set covers each of their own section of the model. One element entity set covers the entire model. The element entity set that I having trouble exporting are elements that are on the surface of the solid model. I use "find" to get all the attached elements to the surface mesh and put them in an entity set. Whenever I check the input file, it's always missing that surface element set. In fact, I would have ID=10 and ID=12 entity set but no ID = 11 entity set with my surface element. My entity set do indeed have elements but for whatever reason and through multiple hours of testing through scripts and GUI, I have failed to export this element set. If anyone can help out or had similar experiences, please let me know. It would be much appreciated!
Sincerely, William
1 - 2 of 21
    User: "Jason_Craanen"
    Altair Employee
    Updated by Jason_Craanen
    Hello,
    Can you verify through the entity state browser the set in question is checked?
    OP
    Hi! I solved the issue.
    The problem occurs when you are trying to export entity sets without its data. My surface entity set includes data points from many other components but I am only exporting only a set of those components. This causes my surface entity set to not be exported but everything else do.
