IGES - Surfaces from Hypermesh to ANSYS Workbench
Hi,
I have a complex geometry that I cleaned on Hypermesh: I have Suppressed edges and no more Free and Non-manifold edges, but Shared edges to define several surfaces.
I exported those 6 new surfaces into an IGES file in order to import them in ANSYS Workbench 15 for meshing and further analysis.
The problem is, once the file is imported in Workbench, I have almost 600 different bodies and visually only a line (which reveals to be a plane surface when I zoom-in a lot...), in other words, I do not recognize my geometry and this is obviously exploitable.
I think my Suppressed edges may alter something ...
Thank you in advance for your advices.
Rahul Ponginan, thank you for your reply.
Yes, I already tried to change the Export Options (Planes, Outer loop, Layers), in vain.
Other formats ? Not really, as I have only IGES choice in Export Geometry. Maybe is there a way to generate a STEP file ?
I tried to export without any Suppressed Edges, in other words, only Shared Edges (but as a consequence I have many surface whereas I wanted just my 6 new ones).
Anyway, this option did not change anything.
@PL_Hyper: Try STEP! For my experience, if STEP is available, always use this format. That's better than IGES.
I would like to try a STEP, but how can I generate this type of file with Hypermesh ?
In Export options there is only a choice for IGES.
Thanks for your advice Q.NEGUYEN-DAI.
Hi PL_Hyper,
what is the version of HyperWorks are you using?
is it a complete suite or student Edition?
After all, I managed to avoid this problem and had a different procedure.
I generated a mesh on Hypermesh and exported it into an ANSYS format.
After what, I imported this file in Workbench and generated a Parasolid from the mesh in order to obtain my geometry (one body).
In any case, thank you everyone for your precious help and advices !
But, I would still have one little question: is it possible to remove definitively a Suppressed Edge (blue one) permanently from an HM model ?
Have you tried changing the various options while exporting (you have a choice called export options), formats other than iges?
so this problem does not occur if you export without suppressing the edges?
