Surfaces copied with elements
When I copy/transform/project elements, the surface which the elements are associated with gets copied/transformed/projected with them. Then, when I hide the surface, the elements are hidden too. It's like the new elements are created in the geometry layer instead of he FE layer. To fix this, I have to manually delete the new surface that came with the elements.
Is this an issue with my settings/install? How can I fix it?
1 - 1 of
11
1 - 1 of
11
Nope, this is intentional. It is a new concept called FE Geometry. See the help page below.
https://2022.help.altair.com/2022/hwdesktop/hwx/topics/chapter_heads/fegeometry_r.htm?zoom_highlight=fe+geometry
