🎉Community Raffle - Win $25
Join and Win
Rubber component meshing
User: "Dragon_heart"
Altair Community Member
Updated by Dragon_heart
Dear All,
I am facing problem in capturing features while Hexa Meshing of rubber component.
Can anyone help in learning for rubber component Hexa meshing.
KIndly share if you have any files and documents.
1 - 11 of 111
    User: "savesagan"
    Updated by savesagan
    Hey!!!
    There is no specific documents available to mesh rubber components.
    only logic matters.
    Please share me the picture of area,where you facing trouble?
    User: "Pranav Hari"
    Updated by Pranav Hari
    Hi Dragon_heart
    You can check this video as well as the learning library for more documents on Hexa meshing.
    https://altairuniversity.com/learning-library/
    Thanks
    OP
    Hey!!!
    only logic matters.
    Hi @savesagan,
    This my component, that I need to do hexa mesh.
    OP
    Hi
    I am little complex one as post in last image. if you have any tutorial regarding this kindly share.
    Thank you
    User: "Simon Križnik"
    Updated by Simon Križnik
    Hi,
    this component is hard to hexa mesh if you don't have much experience. First, you should clean up the geometry (automatically by Geom>autocleanup and manually by F11) to suppress smaller unnecessary features (lines and points). The hardest part is partitioning the solid (geom>solid edit) to get mappable solids- thinking strategically where partitioning surfaces should be to get a nice mesh continuity throughout the component, starting from the most complex segment. Then the surfaces of partitioned solids are 2D automeshed paying attention to mesh transitions- this mesh is then used as a seed for 3D>Solid Map>general.
    As an alternative, you can go for tetra mesh or even solid shrinkwrap (see HM-3150: Meshing a Model Using Shrink Wrap).
    OP
    Hi @Ivan
    Thank you for response.
    I am trying to mesh it.
    In the meanwhile if you get any source to ease for these kind kind of meshing kindly share.
    Regards.
    You're welcome. The following videos might help:
    https://www.youtube.com/results?search_query=hexa+hypermesh
    OP
    @Hyperman
    Thanks for sharing but i am facing rubber component hexa meshing.
    In youtube i didnt find any solution.
    Like @savesagan already mentioned, there is no special way of meshing rubber components.
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    How exactly do you do it if there's no special way of doing it?
    Altair Employee
    Dear All,
    Hi,
    Generally capturing all the features in the rubber component is very difficult one, due to its shape.
    Mostly, for a rubber components... need to capture exactly the center of fillet or within fillet we need to maintain min.2 layers based on element size with respect to analysis engineer requirement.
    Even sometimes we need to compromise the fillet itself for doing hexa-meshing.
    If you need to capture all the features in the component, you can't execute the model through by hexameshing (Because of its nature and complex type in meshing). So kindly proceed via tetrameshing.
    Kindly share your model with your requirements, i will try to help you in hexameshing.
    Regards,
    Saravanan R
