time step calculation
User: "beytut"
Altair Community Member
Updated by beytut
Hello
I have two geometry rectangular and hexagonal.  I used same material and same mesh size for both.
why  their time step is different.
1 - 2 of 21
    User: "Simon Križnik"
    Updated by Simon Križnik
    Hi,
    the difference is because the characteristic element length is computed differently for shell and hexahedral elements:
    -Quad Shell: The square root of the shell area
    The critical length can vary with: • Shell formulation • Hourglass control parameters • Numerical damping • Membrane damping
    -8-node Hexahedral: Volume / largest face area
    I think the characteristic element length should be the same if element shape is close to ideal (square and cube), but could be different for distorted shapes.
    User: "Pranav Hari"
    Updated by Pranav Hari
    Hi beytut
    I recommend you to go through the RADIOSS ebook, Explicit analysis using Radioss  (https://altairuniversity.com/free-ebooks-2/free-ebook-crash-analysis-with-radioss-a-study-guide/) where all the basics for explicit analysis including time step calculations are covered.
    Thanks
