3D cfd mesh
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
hi
 i am doing cfd tetra mesh in hyper mesh when i am converting 2D to 3D i found some error
i) volume analyzer found 1 disjoint element( how can i find the disjoint element)
II) 8 bad elements need to cleanup, re mesh the origin mesh ( how can i rectify this problem and how to fine those bad elements )
what are  quality to maintained in cfd mesh
note: no free edge, no connectivity  error , no duplicate elements
pls help me .........
1 - 6 of 61
    User: "QuyNguyenDai"
    Altair Community Member
    Updated by QuyNguyenDai
    You not 'convert' 2D mesh into 3D mesh. But you can fill a closed 2D mesh with 3D elements (tet4, tet10).
    Before filling, check if your 2D mesh was closed by using: Tool => edges => find edges. If you found nothing, your 2D mesh is closed and you can do next step to fill with TET.
    Altair Employee
    OP
    i used tet10 for cfd 3D tetramesh
    i check edges it show no free edges.
    i got another error
    So check 'failed elems' to understand the issue.
    Altair Employee
    OP
    HOW TO CHECK IT
    When you see the message '71 failed elems saved', do 'F5', select type 'Element' and 'retrieve', 'reverse', 'mask'. You have only failed elements on screen.
    Altair Employee
    OP
    thank you
    but i have another doubt
    volume analyzer found one disjoint element
    what it mean its an error or any other can explain
