🎉Community Raffle - Win $25
Join and Win
hm_measureshortestdistance not working properly
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
                    image.png.aabafc49bd9f6f99cb524bdc5e2f1f30.png                            image.png.1e3de18edb803d25e6c85801c529c879.png
All the brown color elems are 3d elements in the collector solidmap while the green color elems are 2d elems in collector auto1.
I execute the following command
*createmark elems 1 599
*createmark elems 2 'by comp name' auto1
hm_measureshortestdistance elems 1 0 elems 2 0 0
it returns->  0 0 0 0 599 0 0 0 1 0 0 0
but as we can see the distance between elem id 599 and elem id 1 is not 0.and elem id 1 is not the nearest elem to 599 among all other elems of auto1.
Can somebody explain this ?
1 - 9 of 91
    Altair Employee
    OP
    I got the ans, elem is not a valid entity type for this type, the Valid values are nodes, points, lines, surfaces and solids.Apart from this is there any api which can do the task which I intend to do ?
    User: "tinh"
    Altair Community Member
    Updated by tinh
    How about this:
    *createmark nodes 1 'by elem' 599
    *createmark nodes 2 'by comp name' auto1
    set N2 [lindex [hm_measureshortestdistance nodes 1 0 nodes 2 0 0] end-3]
    *createmark elems 1 'by node' $N2
    puts 'closest elems: [hm_getmark elems 1]'
    You can use hm_entityinfo centroid elems
    to get centroid of e599 and the closest elems then compare which one is closer to e599 => decide that is closest.
    Altair Employee
    OP
    hello Tinh
    hm_measureshortestdistance nodes 1 0 nodes 2 0 0 is giving 'expected integer but got '0 ' error ..
    User: "tinh"
    Updated by tinh
    maybe, you copy & paste my code. Be not lazy, pls type it again, man!
    User: "tinh"
    Updated by tinh
    a relevant command you should refer:
    hwat::utils::GetClosestElement
    in package hwat
    Refer HW Help Home> Hyperworks Tools > Hyperworks Automation Toolkit
    Altair Employee
    OP
    Nopes I didn't copy pasted. I typed myself many times but everytime the same error its giving.
    Altair Employee
    OP
    hwat::utils::GetClosestElement first three arguments are x y z coordinates but the last argument is assembly name. This argument is not working if I give the collector name as here 'auto1'
    User: "tinh"
    Updated by tinh
    put that collector (comp) in an assembly,  and use the assembly name as argument
    Altair Employee
    OP
    yes putting that component in a different assembly works. Thanks for the solution . And I tried the hm_measureshortestdistance on a different computer but its giving the same error
