Hi,
I'm working on Hyperstudy and i parameterized 1d beam Dimensions a, b (Hight, width).
I'm facing issue in DOE.
In DOE beam dimensions are not updating in main files (.fem) jobs and its showing as generic in while reviewing.
Thanks.
what solver are you using?
Are you working with a parametrized file? (.tpl)
if it is OptiStruct, you could use PBARL/PBEAML to make it easy to parametrize your 1D model.
Hi Adriano A Koga,
Iam using optistruct solver 19.1 version,
I parametrized the beam dimensions a, b(width, hight) in Hyperstudy .tpl
i used PBAR to parametrize 1D model.
Regards,
Venkatesh k.
Hi Adriano A Koga, Iam using optistruct solver 19.1 version, I parametrized the beam dimensions a, b(width, hight) in Hyperstudy .tpl i used PBAR to parametrize 1D model. Thanks. Regards, Venkatesh k.
in the PBAR you would actually need to parametrize the AREA and Inertia Moments of the PBAR section.
I'd change it to PBARL (if it is a rectangular section), where you enter directly the values of a and b.
https://help.altair.com/hwsolvers/os/topics/solvers/os/pbarl_bulk_r.htm?zoom_highlight=pbarl
in the PBAR you would actually need to parametrize the AREA and Inertia Moments of the PBAR section. I'd change it to PBARL (if it is a rectangular section), where you enter directly the values of a and b. https://help.altair.com/hwsolvers/os/topics/solvers/os/pbarl_bulk_r.htm?zoom_highlight=pbarl
Thanks for the suggestion.
I modified and submitted the job.
Now iam facing some syntax error issue in model.
Below i mentioned error details, please help me out.
*** See next message about line 911708 from file: Sol103_fullmodel.fem "PBARL 70008286 1 +" *** ERROR # 1479 *** in the input data: Incorrectly formatted numeric data in field 9. (If it is a character field, it should start with a letter.) Syntax error(s) in the current line: 911708:PBARL, 70008286, 1, , , , , , >ERROR<
