🎉Community Raffle - Win $25
Join and Win
Connecting two perpendicular mid-surfaces
Hi,
I’m a beginner with altair Hypermesh and today I try to connect two perpendicular surfaces together. My goal is to mesh those surfaces and be sure that the nodes of the horizontal plane are coincident to the ones on the vertical plane. For the moment, due to the mid-surface extraction, I have a gap between the two planes that's why the edge is a 'free edge', from what i understand of the software. I assume that before starting the meshing part, i should connect the two planes together and have a 'shared edge'... Is it the right way to deal with this situation ?
Thank you very much for the help
1 - 3 of 31
