K and C Report Missing
Greetings!
I am going through the Vehicle Modeling E-Learning and every time I run a Kinematics and compliance test, I am always missing the page 40 (K & C Report) page that the e-learning has populate each time. I am selecting and looking through to make sure if there are any boxes left unchecked, but I cannot figure out why I am not getting the page 40, K & C report for the simulation of a half body vehicle from the vehicle tools wizard.
I should clarify I am selecting the SDF-Based Report when going to the report log. I saw in the preferences that there is a pre-2020 output file for the motion solve, i wonder if that would change it?
Hi Joranaw,
You can also find the sdf report in your output directory (where you set this in the analysis settings). By viewing that location you shall see a file marked .sdf. You are able to open it in any notepad editor.
Best,
Christopher Fadanelli
Hi Jordanaw,
There is a known issue with the SDF appearing in the automatic report that is to be remedied in a future release.
The report is still created in an .SDF file in the output directory, so the results are still available and viewable with a text editor.
Hope this helps!
Adam Reid
Thank you so much! I found what you were referring to.
Hi Jordanaw,
Hope this helps!
Adam Reid
