🎉Community Raffle - Win $25
Join and Win
Composite Plate Theory
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
I'm using PCOMP to model my composite structure, I wanted to know that which theory does it use to solve?. Is it possible to change the theory from CLT, to first order shear deformation, or higher order shear deformation?
1 - 2 of 21
    Altair Employee
    OP
    Hi Akshay,
    OptiStruct uses classical lamination theory to calculate effective stiffness and mass density of the composite shell.  This is done automatically within the code using the properties of individual plies.
    The composite interlaminar stress is calculated based on the first-order shear deformation laminated plate theory.
    Altair Employee
    OP
    Hello Prakash,
    Thank you for the information.
