Export beam model for bolt connection Dyna
Hi
So I created a model where a have two rigid bodies inside a hole in front of each other and they are both linked by a beam. I was wondering if there was a way to export this model in oder to not have to proceed by this method to create a bolt by using this definition for the bolt connection tool in hypercrash.
Thanks
