🎉Community Raffle - Win $25
Join and Win
Convert surface into volume
User: "VirgileV"
New Altair Community Member
Updated by VirgileV
Hi , I'm using Solid.Inspire and after using polynurbs I obtain volumes and surfaces (don't know why) as shown in picture attachment -surfaces are red circled.
Can I convert those surfaces into volumes in order to export in CAD ?
Thanks for answers
BR
Virgile
1 - 3 of 31
    User: "Mario_21478"
    Updated by Mario_21478
    Hello,
    As you can see in the model browser, there are 2 surface parts (flat surface, instead of cube; nb. 6 and 6.2).
    Since the mass is zero, they also have no thickness.
    If the object has still all surfaces to build a enclosed volume, than you can try to 'Boolean->Combine->Pick the part(s) in browser->Press 'combine'.
    Otherwise you have to check it for open holes, close it and try Boolean.
    Best Regards,
    Mario
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Agree on Marios advice!
    You can check for open volumes by using the 'patch' command.
    Regards,
    Felix
    User: "VirgileV"
    OP
    Updated by VirgileV
    thank you for all answers
    Regards
    Virgile
