1180 Error in WinProp simulation
With the 2021 student version installed, I have some problems when trying to run some propagation simulations on WinProp. Even though with some projects it correctly runs the simulation, I am usually prompted a 1180 error message in the progress bar.
I attach some screenshots of the message. It is yet a simple scenario, with only 1 transmitter. Then, I do not think it may be due to any limitation on the student version.
I would strongly thank if you could help me.
UPDATE: I have checked that the problem comes whenever I select the "Transmission Matrix" result in the "Propagation" tab of the "Edit Project Parameter" menu. If this option is left unselected, the simulations can be computed without problems. Why does this happen?
