I'm new to HyperWorks and I noticed that when I put some nodes on a surface, the mesh does not cross them (see photo below). Eventually I see the results are not right because of this.
Apparently, you have created so-called temporary nodes (in yellow). These nodes are not recognized during the meshing (as you are meshing the surface/geometry). Hence, you need to create geometry points instead (you will see, that geometry points will also be highlighted when you select the geometry).
Hi,
Regards
Matthias
