🎉Community Raffle - Win $25
Join and Win
convert a STL mesh file into solid part
User: "Rahul_P1"
Altair Employee
Updated by Rahul_P1
Do you know how to convert a STL mesh file into solid part for finite element analysis?
Using stereo-photogrametry tech I have a geometry of the structure in the STL format. Now I try to import it into hypermesh for FEM analysis.
I will appreciate it if you help me.
1 - 5 of 51
    User: "Rahul_P1"
    Altair Employee
    OP
    Updated by Rahul_P1
    STL files can be imported into HyperMesh, You need to use File > Import > File type > STL and then choose the file.
    Once the STL file has been imported you can then use Geom > surfaces from FE and select the highest complexity in this panel > select the elements to create surfaces from STL, hence you can create geometry from stl.
    To directly solid mesh your STL use ShrinkWrap
    You can achieve a good tetramesh for all purposes, using the Shrink Wrap panel. The shrink wrap can generally be used as a quick mechanism to generate solid meshes.
    1. Go to 2D > Shrink Wrap panel.
    2. Here there is an option generate solid mesh – this will produce an all-hexa or all-tetra mesh based on the selected elements or geometry.
    3. Make sure the generate solid mesh checkbox is active
    4. This will expose a tet collapse input, please try several input values depending on your quality requirements.
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hi Rahul,
    I can't find the following path:
    ' File > Import > File type > STL '
    I can only see the attached options.
    My problem: I have a stl mesh file of a simulation programm and want to convert it to a solid and smooth the surface for an analysis in ANSYS.
    Can you please help me?
    Kind regards
    Alex
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    This import option under FEM is available in full version not in Student edition.
    Altair Employee
    Ok, thanks for the information!
    Altair Employee
    Hi Rahul Ponginan,
     i done all what you said, but creating some surfaces was failed .does it refer to my Complicated geom?
    can you help me what should i do?
