🎉Community Raffle - Win $25
Join and Win
Fix ERROR 40619 Intersecting elements found in EDITFEKO
User: "mkovaleva"
Altair Community Member
Description: [I need to automate an antenna array generation. First, I import a .cfm (mesh model) file of my antenna. Then, I generate a finite ground plane. I end up with 13 intersecting triangles. While I can manually delete them and create new ones on CAD FEKO, it is not a solution to my problem because this has to be done for a very large array. Is there an EDITFEKO card that meshes the ground taking into account existing antenna mesh triangles? Or I can fix the ground for one antenna and import a .cfm file with a small ground plane, but later, when I add all other antennas, how do I unite the ground planes?]
Product/Topic Name : [EDITFEKO v2022, FEKO]
