Temperature of the particles are not matching. I am not sure about the reason although the set all the values mentioned in the attached pdf.
Please find my attached setup. Let me know if I am missing some details or additional inputs.
Hoping for your valuable suggestions. Thanks.
Hi,
In the paper it says that the authors a custom model to simulate the heat transfer. That's why the results are different from the built-in model.
Regards,
Renan
Any tutorial to develop the heat transfer api code?
Hi,
Regards,
Renan
