Topology Optimization - DRESP2 - DEQTN
Is it possible to perform a topology optimization (obj=min mass) by setting as constraint the difference between two nodes? I understood that I have to use a DRESP2 and an dequation to link the nodes: the function I wrote is f(x1,x2)=x1-x2 I have many couples of nodes to monitor. If there is an example/tutorial how to write DTABLE and what I have to put as DESVAR will be very useful.
Thank you!
Adele
1 - 1 of
11
i'm not sure if DTABLE would help you here, as it defines a bunch of constant values.
For your purpose, for each pair of nodes, i believe you will need to create 2 DRESP1, and 1 DRESP2 + DCONST for applying constraints.
I'd say the best way to do that, for many nodes, is:
But in essence>
DEQUATION> f(x1,x2) = x1 - x2
DRESP1 of type DISP, defining the component (X,Y,Z, or total) and node ID1
DRESP1 of type DISP, defining the component (X,Y,Z, or total) and node ID2
DRESP2, calling DEQUATION, and DRESP1's in ordered manner » if this is applied to a specific loadcase, this could be specified right away.
DCONSTR calling the DRESP2 and assigning the lower and upper boundaries.
…repeat
depending on the setup, a DCONADD should also be created to combine the multiple constraints.
