🎉Community Raffle - Win $25
Join and Win
Distributed pressure in Hypermesh 2024.1
User: "bjjoo"
Altair Community Member
Description:
Hello, I want to apply distributed pressure on specific surface. The pressure to be applied changes along the x-axis. And that pressure value is irregular. So I can't use equation thing.
(just like this)
Product/Topic Name : Hypermesh 2024.1
*Note from Community Team - Once you receive a satisfactory answer on your question, kindly mark your answers as "Accepted" so it can help others with similar problems. Thanks.
1 - 3 of 31
    you should be able to define this using Equations while defining the pressure magnitude.
    Create a local coordinate system, and then applythe pressure using an equation as shown below.
    User: "bjjoo"
    OP
    Updated by bjjoo
    Thank you for reply, but I can't use equation. Is there any way to use tabular data to apply variable magnitude? Using field might be possible in that case, I don't know how to use it.
    not exactly, but similar using field mapping:
