🎉Community Raffle - Win $25
Join and Win
Help with Hyperstudy and EDEM to make different tests for clay sticking inside a dumper.
User: "Karl_H"
Altair Community Member
 Hello!
I am both using Hyperstudy 2025 and EDEM 2025.
I am working on a project where I fill up a dumper with particles and then dump it. I have had some problems to find good combinations of surface energy and other parameters for the physics models so the particles stick naturally to the dumper, so the residue in the dumper looks like real world examples. I was thinking on if I could use Hyperstudy to try different parameter combination but I have had some issues. I was thinking if it was possible to make Hyperstudy save only the last timestep so I can look at each trial and see how the particles behave with the different combinations of parameters. Is this possible? and if so how?
BR
