Solids from 3D mesh
Updated by Altair Forum User
IS it possible to get 3D features from FE entities.
I can only see the option for surfaces but not for 3D FE entities.
1 - 5 of
51
This is okay. But isn't there an easier and proper way to create solids around an existing 3D mesh?
Go to tool > faces to create surface elements
Go to surfaces > from FE to create geometric surfaces from the above created surface elements
Then use geometry > solids > bounding surfaces to create solid geometry from the bounding surfaces.
This is not working for spheres! I get errors
Hi Chaithanya,
You may have to extract face elements from solids. On these face elements you can get the features.
