How do I translate a number of nodes on the 1 DOF in a cylindrical system>
I have a cloud of node or elements I need to translate in a cylindrical coordinate system on the 1 DoF (Radius). This was simple to do in the old interface but I cannot get it to work in the new interface. If I select the 1 DoF on the local cylindrical system it does a translation in a cartesian coordinate system manner.
HyperMesh 2023.1
1 - 1 of
11
Hello, I believe you received this answer already, but here it is for the rest that could use it
You can work with the Transformation Tool:
As you already have a local system defined, you can just define the "System Type" as Local and then select the desired system and a base node.
Here are some links that covers more about these features:
Transform Elements
Translate, Rotate, and Position Entities with Transformation Tool
