🎉Community Raffle - Win $25
Join and Win
Surface split issue in HyperMesh 2021
User: "Akshay Manthekar"
Altair Community Member
Updated by Akshay Manthekar
Hi Guys,
I have created a macro which will split the surfaces at specified distance. It is working perfectly in HM 2017.3 version but its not working properly in HM 2021.2 version. You can see the following images. Can anyone help me what is the issue here? Are you also facing the same problem?
Your Help is much appreciated.
Thank you in advance!
1 - 1 of 11
    Hello Akshay Manthekar,
    Can you check that you are using non deprecated command? For that you can use the script parser.
    https://community.altair.com/discussion/39691/reviewing-your-hyperworks-scripts-compatibility-with-script-parser
    Regards,
    Marine Racollet
