Periodic Boundary Condition in EDEM Fluent coupling
Hello everybody,
I am simulating a tube with particles by Fluent-EDEM coupling.
Both of the program works well individually.
When I coupled them and used periodic boundary condition, the particles enter in both side of the tube!(inlet and outlet).( the screenshot has been attached).
I selected the periodic direction correctly (Y direction).
Could you please guide me what's the problem?
Regards,
Fatemeh
Hi,
I would move the particles away from inlet or run the simulation for a few timesteps first so the flow is well developed.
My hunch is that you have reversed flow at the inlet or outlet, which is not uncommon in Fluent, which is then pulling particles in the wrong direction initially and leading to them appearing in the other side due to the boundary condition.
Cheers,
Richard
Hi Fatemeh,
It looks like there might be some instability in the coupled simulation. I would recommend running at a lower time-step ratio between EDEM and Fluent (lower fluent time-step) to see if this improves stability.
Otherwise ramping up the initial velocity of the fluid and starting from a lower creation rate of particles may help to ensure stability of the model at the start.
RegardsStephen
Many Thanks Stephane. It works.
Just for the people who may have this problem:
1. The fluid time step is reduced from 2e-5 to 1e-5.
2.The initial fluid velocity is increased from 0 to 2 m/s.
3. The particle rate is reduced from 600000 particle/s to 200000 particle/s.
Regards
Fatemeh
Hi Fatemeh,
Regards
Stephen
Hi Fatemeh,
Regards
Stephen
