🎉Community Raffle - Win $25
Join and Win
Error: "Impossible to open MATERI.DAT" in Flux
User: "Flomiko"
Altair Community Member
Description: I generated a 2D geometrey in Altair flux. After that i generated the Mesh. After that I tried to specify the material by clicking "import material .DAT", but I always get the following error: "Impossible to open MATERI.DAT
Failed convert object : null pointer."
Product/Topic Name : Flux 2025 - Flux2D - Magneto Static
1 - 1 of 11
    Hi Flomiko,
    Can you please check if your paths to material database is correctly defined or not as in the picture below?
    If it is same and still you are getting an error, I suggest bringing materials from Material manager. You will have access to more materials along with the materials in Material.DAT data base.
    Thank you,
    Lavanya
