🎉Community Raffle - Win $25
Join and Win
difference between ansys and hyperworks results
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
I am a new user of hyperworks and i generally work with ansys workbench, I have been trying to verify the results of same mesh on both softwares but I am not able to get the same results. I have checked my methods a few time and I haven,t found as such any errors, but I am still doubtful about the units used in hyperworks and any other error that i may have missed.
1 - 2 of 21
    User: "Jan Grasmannsdorf_20379"
    New Altair Community Member
    Updated by Jan Grasmannsdorf_20379
    Hello,
    there might be many reasons, why you wont get the same result between two different solvers.
    For a linear static analysis in HyperWorks, your model looks fine, so I would definitely trust the results that you are getting. The reasons why they differ from Ansys might be:
    1) In Ansys, you might have different Element Type (e.g. Tetras instead of Hexa / Brick elements) or a different element order (you use 2nd order elements in HyperWorks)
    2) Ansys workbench might change or adapt your input or boundary conditions without notifying you, e.g. at the constraint locations
    3) maybe you use a linear static analysis in HyperWorks and have defined something different (large deformation or non-linear analysis) in Ansys?
    4) You might have a different location of your stress ( in HyperWorks stress is at the element center by default)?
    Altair Employee
    OP
    Hi,
    Thank you for the help, the location of stresses in both software's were different that's why i couldn't verify the results.
