🎉Community Raffle - Win $25
Join and Win
Slow processing in Hypermesh11
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
I am using Hypermesh(v11.0). While performing meshing activity the processing takes more than normal time.
Like if I am meshing(or remeshing) even few elemets it takes more time to create or edit elements.
I tried resolving the issue by cleaning 'command.cmf', 'hmmenu.set' which are created in 'Start in' directory on
the hard disk and again re-running the Hypermesh but still in vain. This issue occurs intermittently.
Any solution on this problem is appreciated.
Thanks & Regards,
Tushar J M
