Slow processing in Hypermesh11
Altair Forum User
I am using Hypermesh(v11.0). While performing meshing activity the processing takes more than normal time.
Like if I am meshing(or remeshing) even few elemets it takes more time to create or edit elements.
I tried resolving the issue by cleaning 'command.cmf', 'hmmenu.set' which are created in 'Start in' directory on
the hard disk and again re-running the Hypermesh but still in vain. This issue occurs intermittently.
Any solution on this problem is appreciated.
Thanks & Regards,
Tushar J M
increase your virtual memory, update your graphic cards drivers, use the latest altair updates.
0 -
Yeah, it's good time to upgrade to HW 12.0
/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
