EDEM with core-processor error
Hi, a bit late but just adding an answer to this question. It's not always clear what could cause this but I would ensure that you are using the latest version of EDEM (currently 2024.1 but 2025.0 to be released soon). Also ensure you GPU drivers are up to date.
It could occur if the GPU memory is full in which case reducing the number of particles would help.
Regards
Stephen
