load visualization about new version hypermesh2024.1
Hi @yhr_123,
You can visualize value of the load and resize load vectors in HyperMesh 2024.1.
In Preferences, there is a option to change size of the load vectors and constraint triangles. Type 'load' in search bar and you see the options about load appearance.
To visualize value of the load and constrains on model, open Display Load Handles option in Element Handle Visualization.
I hope it helps you.
Hi @yhr_123,
In HyperView, Forces can be visualized using the Vector Tool. The Display can then be modified to scale the vectors to the desired size:
This example was completed using a MotionSolve simulation, however the process should be the same for HyperMesh.
Hope this helps!
Adam Reid
Hi @yhr_123,
Hi @yhr_123,
Hope this helps!
Adam Reid
