Help in Altair Flux... Induction Heating Applications
CarlosGarcia3DXPERT
CarlosGarcia3DXPERT Altair Community Member
Hello,
I hope this message reaches the right team.
I would like to ask if Altair Flux has the capability to calculate the hardening values of metal components, such as gears. If so, could you please provide an overview of the workflow for performing this analysis?
Thank you in advance for any assistance you can provide.
Best regards,
Answers
  • Letizia_Ferrara
    Letizia_Ferrara
    Altair Employee
    Hello Carlos,
    Could you please specify what you mean with "calculate the hardening values of metal components"?
    To give you an idea of what we can do with Flux, you can find here 2 examples where the hardening process is analyzed within Flux.
    Site favicon2D Example: Induction heating with multiphysics coupling tutorial
    Site favicon3D example: Magneto thermal application (Technical paper)
    As you will see, the thermal solver in Flux can be also coupled with the electromagnetic one in order to stay in the same environment and thermal Boundary Conditions should be defined, as well as the material properties.
    I hope this can help you. You can create a ticket in the support section indicating Flux as tool in case you will need help to model your case study.
    Best regards,
    Letizia
Welcome!
Welcome!
