🎉Community Raffle - Win $25
Join and Win
Cannot reproduce the EDEM-HyperStudy Connector tutorial results
User: "jc_794"
Altair Community Member
Hi,
I am learning EDEM-HyperStudy Connector with the official tutorial from this link:
https://community.altair.com/discussion/35630/edem-hyperstudy-connector-installers-and-user-guide
However, when I implemented the step to export the 'responses.csv' file, the file could not be generated like the guided video.
I tried to debug the process and found the key point was when Hyperstudy ran the "edempy_post.py", the "contacts = deck.timestep[i].contact.surfSurf.getContacts()" variable cannot be successfully retrieved. The screenshot of the attempted debugged process is shown in the following:
The interesting thing is that when I tried to retrieve this data in a newly opened Python file, it worked:
The Python environment that I used was the default version, 3.8.10, and the HyperStudy was v2024.1.0
Your suggestions are valuable. If there are any other people who faced the same issue as me when running the tutorial case or If you can run this case smoothly, please don't hesitate to let me know.
