🎉Community Raffle - Win $25
Join and Win
Tcl code to get components id list from part id/name?
User: "Sandeep Kumar Mahto"
Altair Community Member
Hello Team
I am working on script for mass balancing, through part selection. if i will get component list of respective part then I can create material with new density and can assign to respective property.
need tcl code that can give component list after part selection.
i worked at component level already but need on part level.
Thanks and regards
Sandeep
1 - 4 of 41
    Hello @Sandeep Kumar Mahto ,
    For mass balancing, please note we introduced in version 2024.1 a Mass Balancing tool, which allow to generate non-structural mass:
    Could that help?
    Best Regards,
    Michael
    OP
    Hello @Michael Herve_21439
    thank for response.
    before NSM, we do mass balancing at part level first by changing density. after that we go for NSM.
    Thanks and Regards
    Sanddep
    User: "Michael Herve"
    Altair Employee
    Accepted Answer
    Hello again,
    from a part, you should at least be able to get the list of components:
    set CompList [hm_getvalue module name=part_name dataname=HW_CID]
    Depending on the solver, you may also be able to get directly the property and/or material:
    set PropList [hm_getvalue module name=part_name dataname=HW_PID]
    set MatList [hm_getvalue module name=part_name dataname=HW_MID]
    Hope that helps,
    Michael
    OP
    Thank you so much, It is working.
    Thanks and Regards
    Sandeep
