🎉Community Raffle - Win $25
Join and Win
HyperBeam Plastic Section Modulus
User: "Vladimir_Gantovnik"
Altair Community Member
Updated by Vladimir_Gantovnik
Guys, when I create in HyperBeam Standard Sections/OptiStruct/Bar, it gives Plastic Sect Moduli equal to zero: Zy=0, Zz = 0. But when I create same solid section manually, I see the values.
Thank you!
1 - 1 of 11
    User: "Jason_Craanen"
    Altair Employee
    Accepted Answer
    Updated by Jason_Craanen
    Hello,
    • Solid section is FE based solution, hence accuracy of some quantities may be subject to mesh density
    • Standard section are closed form solution, mainly meant to feed PBEAM card hence some quantities are not evaluated.
