Transfer component structure from Siemens NX
User: "Annika_Amazone"
Altair Community Member
Hello everyone,
I would like to use the component structure from Siemens NX in Motion View. I have the problem that I work with complex component structures that are very conveniently summarized in NX. If I now export the assembly to MotionView to edit it further there, the entire part structure falls apart and I have 1000s of unstructured parts. Does anyone know how I can import assemblies into MotionView or export them from NX so that MotionView takes over the part structure?
Thanks
Translated with DeepL.com (free version)
1 - 2 of 21
    User: "Orestis_YB"
    Altair Employee
    Hello @Annika_Amazone,
    in your case I would suggest to use Inspire for CAD import and check the structure of your assembly there. I believe it will remain as is in NX. There through Motion tab you can even start setting up your MBD model. Many MBD entities are available there . Both Inspire Motion and MotionView utilize MotionSolve for the simulation. In case you need tools that are available in MotionView you can always export your Inspire model to MotionView (Export Motion Model) and continue working there.
    Here you can find an introduction Inspire Motion E-Learning.
    Hope this helps!
    Best regards,
    Orestes.
    OP
    Hello @Orestis_YB
    Thank you for the tip. I will try it out.
