🎉Community Raffle - Win $25
Join and Win
How to import (Abaqus) results file .odb into Hypermesh in order to prepare a second step on the deformed geometry?
User: "Rafal Blasczykowski"
Altair Community Member
Updated by Rafal Blasczykowski
Hello!
I want to make a new implicit step after one explicit has finished.
I tried running first the explicit and then, importing the .odb to a new .inp:
*MODEL CHANGE, REMOVE
**Here I remove some of the sets I don't want in the new step
*IMPORT, UPDATE=NO, FILE="test1.odb", STEP=explicit_Step
*STEP, NAME=implicit_Step
*STATIC
*CLOAD
N111900, 3, -1000
*BOUNDARY
Boundary1, 1, 6
*OUTPUT, FIELD
*NODE OUTPUT
U
RF
*ELEMENT OUTPUT
S
E
PE
*END STEP
But this is not working:
Abaqus Error: No import file was specified.
The Abaqus analysis cannot be executed.
Abaqus/Analysis exited with error(s).
The .odb is in the same directory that the .inp. In spite of this circumstance, I've tried also putting the whole route here FILE="test1.odb", but it works neither.
Does anyone know how could I make this?
Thank you.
1 - 1 of 11
