Hi there,
I wanna calculate the range between two dates less than 3 months:
I made it as
if(date_diff(PerformedDate,LatestDate<7,776,000,000),1,0)
3 months = 7,776,000,000 milisec
But I get an error as "must have arguments of the same type"
Both date are the same date format.
Any recommendations?
date_diff() takes two date/time attributes. You are passing "LatestDate<7" as the second parameter, that would be a boolean result.
This would be a syntactically correct form of the formula:
if(date_difff(PerformedDate, LatestDate) < 7776000000), 1, 0)
Numbers must be specified without the thousands separators in the formula.
Regards,
Balázs
