🎉Community Raffle - Win $25
Join and Win
Is there any possibility to include static- and dynamic friction in kinematic joints of any kinematic mechanism, particularly with using NLSTAT/NLTRANS subcases and with Optistruct Solver?
User: "Patel"
Altair Community Member
Updated by Patel
Dear Sir/Madadm,
Could you please explain me, whether it is possible to include friction in kinematic joints of any mechanism with using Optistruct Solver and also with NLSTAT/NLTRANS subcases? We can definitely use PCONT for defining static- and dynamic frictional coefficients between two surfaces through contact definition, but can we also implement these in kinematic joints? Basically we want to do  FE-Analysis of a kinematic mechanism with considering static- and dynamic friction. With local Altair support, I got to know that we cannot calculate such a problem, but can we develop a particular method in which we can include static- and dynamic friction in kinematic joints of any mechanism?
Thanking you in advance.
Best regards
Ravi Patel
1 - 5 of 51
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    You could use Altair Inspire for such kind of FE Analysis to incorporate kinematic mechanism with static and dynamic friction. Please refer below Youtube video.
    User: "Patel"
    OP
    Updated by Patel
    Hi Rahul,
    Thank you for the answer. Yes, we can do MBD Analysis with considering frictional properties in Inspire, but I want to perform FE-Analysis of my kinematic mechanism. I mean, I want to use each component of my kinematic mechanism as flex body, also with subcase - NLSTAT or NLTRANS (with Large Displacement)... and all of these with static- and dynamic frictional co-efficients in all the kinematic FE-joints.
    I also tried Inspire structre module to enter joint frictional properties in my kinematic mechanism, but after entering static- and dynamic frictional properties in Inspire Structural module, when I tried to generate .fem file through Inspire and ...opened it in Hypermesh, I couldn't find these static- and dynamic frictional properties.
    Yes, we can also do such calculations with MBD Analysis including friction in kinematic joints, but actually we want to see how the frictional properties in kinematic FE-joints affect in FE-Analysis results.
    For now it is not possible to define static and dynamic friction in structural JOINTG elements.
    User: "Patel"
    OP
    Updated by Patel
    Is it possible the same problem (with friction in kinematic joints) to be solved with Radioss Implicit/Explicit solver?
    User: "Simon Križnik"
    Updated by Simon Križnik
    Hi,
    friction in kinematic joints is available in Radioss: /PROP/TYPE45 (KJOINT2).  Frictional force versus displacement function is input instead of static and dynamic friction coefficients.
    Motionsolve does support CMS flexbody and friction in kinematic joints.
