Preserve rows during text processing
Hello Rapidminer friends - I'm trying to process some text for sentiment analysis and have gotten stuck. I have an excel spreadsheet with about 3000 rows, each of which is a free-text comment expressing sentiment towards an experience. I would like to use the "Extract Sentiment" operator from the operator toolbox extension to allocate a sentiment value to each individual comment.
I am importing, changing nominal to text, and then using process documents from data with the sub-operators Tokenize, Transform Cases, Filter Stopwords (English), Filter Tokens (by Length), Stem (Porter). When I check the results at this stage, each row is associated with a token rather than an original string of tokens that would have formed a row. Is there a way around this, or of re-stitching discrete tokens back together after the above steps? I need to allocate a sentiment to each row within the spreadsheet, rather than the entire spreadsheet.
Many thanks for your help - and apologies if this is a newbie query
