Hyperview Keeps on "Not Reponding" state
Rod
Rod Altair Community Member
edited October 2020 in Community Q&A
I have always experience this freezing of Hyperview. My version is HV 2017.
Every after few minutes, my Hyperview just freeze. So i have to open another HV to visualize results.
Does anyone here knows any solution to this problem? I have used 2 different workstations but still it happened.
Workstation 1:
core i7-9th gen
16Gb RAM
Quadro P2000
Workstation 2:
intel Xeon 2236
Quadro RTX 3000
32Gb RAM
Even my desktop with GTX 2070 nor my laptop with i7-8th gen and On-board graphics all experience the same issue. That might mean that the issue is on the software itself and no longer on the machine. Can anyone shed a light on this?
Answers
  • Rod
    edited December 2019
    On top of that, I cannot open multiple views in HV when I use the Workstation 2 with RTX 3000 GPU (a very capable GPU). I wonder if I have to change some settings on the GPU to make the HV show the multiple views option.
    'Edit'
    Multiple views is not ok. I just unchecked the 'Enable GPU Computation' under Options --> Performance in HV.
  • Koushik Chandrashekhar_21806
    edited February 2020
    Hi,
    Kindly do the clean up as mentioned in the attached document and then see if the issue persists.
Welcome!
Welcome!
